protected-mgmt-frames
Configures the
WLAN's frame protection mode and SA (security association)
query parameters802.11w provides protection for both unicast management
frames and broadcast/multicast management frames. The ‘robust management
frames‘ are action, disassociation, and de-authentication frames. The
standard provides one security protocol CCMP for protection of unicast
robust management frames. The PMF (Protected management
frames) protocol only applies to robust management frames after
establishment of RSNA PTK (Robust Security Network association
Pairwise Transient Key). Robust management frame protection is
achieved by using CCMP for unicast management frames,
broadcast/multicast integrity protocol for broadcast/multicast
management frames and SA query protocol for protection against
(re)association attacks.
- Access Points:
AP3000/X, AP5010, AP310i/e, AP410i/e, AP505i, AP510i, AP510e, AP560i, AP7602, AP7612, AP7622, AP7632,
AP7662, AP8163, AP8533.
- Service Platforms:
Syntax
protected-mgmt-frames [mandatory|optional|sa-query [attempts <1-10>|timeout <100-1000>]
Parameters
protected-mgmt-frames |
Enables and configures WLAN's frame protection mode and
SA query parameters. Use this command to specify whether management frames are
continually or optionally protected. Frame protection mode is disabled by
default. |
mandatory |
Enforces PMF on this WLAN (management frames are continually optionally
protected) |
optional |
Provides PMF only for those clients that support PMF
(management frames are optionally protected) |
sa-query [attempts <1-10>| timeout
<100-1000>] |
Configures the following SA parameters:
- attempts <1-10> – Configures the number of SA query attempts from 1 - 10.
The default is 5.
- timeout <100-1000> – Configures the interval, in milliseconds, used to
timeout association requests that exceed the defined interval. Specify a value
from 100 - 1000 milliseconds. The default value is 201 milliseconds.
nx9500-6C8809(config-wlan-test)#protected-mgmt-frames mandatory
nx9500-6C8809(config-wlan-test)#show context
wlan test
ssid test
bridging-mode tunnel
encryption-type none
authentication-type none
Related Commands
no (wlan-config-mode) |
Disables enforcement of protected management frames on this WLAN. And reverts
protected management frames sa-query timeout and attempts to 201 milliseconds and 5
respectively. |
